[MENTION=3]Gairo[/MENTION] How did this post happen ??
is it possible to add rear Electric Rear Door Windows. from main dealers !
the front has electrics but not rear ?
I understand Flux capacitors are on back-order
Weve had them on back order now for 3 months theyve got to be especially made
No, it's not possible to fit rear electric windows on an Astra J, same scenario as AFL's etc, the looms are specific so you'd need a complete car to replace the door cards, motors, door looms, main dashboard wiring loom and ECU, then you need the dealer codes for Tech 3 and they won't release them, if you want an Astra J with AFL:'s and rear electric wiondows, you'll need to buy the car with them fitted from the factory.
Tech3?????
Simple solution is plug it into tech 69 and eat away at the issues you will face !!! Lmao.
