anyone know a good place for dual mass and clutch replacement??
myns slowly on its way I think, got a slight pulsing judder on tick over and under load in a high gear jut feathering the throttle get a nasty judder but fine when I plat my foot
I might be wrong but I don't think that is the clutch...
Simple way to test the DMF is keep engine on tickover and depress the clutch pedal slowly, if you hear a rattle as the pedal goes down, then the DMF is on its way out.
But out you can still get a few thousand miles out of it.
Mine has been rattling for 12 months now and still going strong.
It's a ot of money to spend to find out that it wasn't the clutch and DMF.
Ian, that could also be the thrust bearing on its way out if it rattles on idle as you explained.
