Yeah underneath the black cover i know a few that have come loose at the big nut after fitting em..
Think I might try re-fitting them and see from there is it worth put some grease on the rubber on top mounts?
Its one ov them what happens when only driving slow after going up to see ginger later as he fitted them lol hopefully he can sort them out
Ye wack a bit of grease on the top mount m8 as you say , it can't hurnt nuffin can it and recheck the coilover has been put together right while its off
Going to give it ago later hopefully works
If it doesn't work and I see any of you I will flash to have a look haha
Ash will sort it out hes a good lad
Not knocking him he does all my stuff on my car haha family thing haha
I had the same noise and it turned out that the actual shock was smaller than the genuine so it put more tension on the ARBL and made it start rubbing and knocking of the chassis. U need short ARBL's but there hard to find
Did you sort sone for yours?
