Description
Cruise control will maintain your car at the speed you set it at, with no need to use the accelerator.
Requirements
To function, cruise control requires the following to be fitted and working:
  • Cruise control Stalk
  • Clutch switch
Part Numbers
Astra H
Stalk - Right hand drive
13129642 -SWITCH, ASSY., TURN SIGNAL/DIM/DIP, LH (FOR ELECTRONIC CRUISE CONTROL) (IDENT WM)
Stalk - Left Hand Drive
13129643 - SWITCH, ASSY., TURN SIGNAL/DIM/DIP, RH (FOR ELECTRONIC CRUISE CONTROL) (IDENT WP)
Clutch Switch
55701396 - SWITCH, CLUTCH PEDAL
