Just wondering if I can make the heaters blow harder ?thay seam slow,or is it the same on mk4 astra???
My heaters are fine.. Never really have the fans higher than 2 and thats plenty when its cold anymore and you will dry up lol
Have you changed the pollen filter?
I'll have a look at the pollen filter, where is it? Lol
It's always been weak blowing it takes ages to clear the windows
Yeah try changing that. Its behind the glovebox. Unscrew the glovebox and you'll see a thin black plastic cover with 2 nuts. Undo the nuts and pull the filter out.
Sometimes there will be a blower pipe in the way on some models.. If not its as simple as adz said.. If pipes in the way it can be moved out the way but its fidly lol
Nice one lads I'll give that a try
Na mine am quite quick aswell my bet is the pollen filter is not allowing the fan to suck air in
Cheers lads new pollen filter fitted,no more waiting 15 min for screen to clear. Best £5 iv spent
Good glad to hear it sorted m8 and you learn summat new every day aint it
