Results 1 to 10 of 12
    vectraross
    Guest vectraross's Avatar
    Bulb flickering issues
    put some hid h7r bulbs in the astra not bad but flickering slightly...is this bulbs or ballast im thinking of changing the bulbs to the shorter ones anyone else done this? astra twintop and hatch
      Member Adz's Avatar
      May 2012
      West Bromwich
      595
      Various
      Are they both flickering together or is it just 1 side?
      Member Adz's Avatar
      May 2012
      West Bromwich
      595
      Various
      Just noticed this is in the wrong section too.. [MENTION=3]Gairo[/MENTION] [MENTION=5]Smiffy[/MENTION]
      vectraross
      wanted quick answer thats y its here bud...its both sides doing it
      Member Adz's Avatar
      May 2012
      West Bromwich
      595
      Various
      Quote Originally Posted by vectraross View Post
      Dont worry about the wrong section mate. Im sure one of the mods/ admins will move it. I didnt mean as in here on the forum I meant here as in the mad house and not car chat
      Im guessing it could be ballasts. Normally it is ballasts that make it flicker. Well from my experience anyway. Best to see if you can get a spare set of bulbs or ballasts off someone to test it with
      Member ANT-VXR's Avatar
      Apr 2012
      1,517
      Id have said a ballast problem but wierd how they both doing it
      vectraross
      thats what i thought ive got a ballast somewhere ill chuck it on see what happens
      Member Woody VXR's Avatar
      May 2012
      161
      Wht years the astra ? Cus the Canbus system makes them flicker to
      Sent from my GT-I9505 using Tapatalk
      vectraross
      2006 its only a slight flickering they look almost loose as if there rattling with engine on but they do it when engine off...ive put leds in they dont flash.
      Member paulwhite1987's Avatar
      Dec 2013
      wombourne
      42
      zafira b
      Happened when I fitted hids to my old mondeo. Bought a relay loom to take the live feed direct from the battery and used the bulb connector as a switch. Worked a treat
      Sent from my HTC One using Tapatalk
  1. HIDs flickering - need programming?
    By Dilan21 in forum Astra
    Last Post: 7th August 2014, 11:04 PM
  2. Turning Bulb Check Off
    By Jamezz Sanjay Ghai in forum Corsa
    Last Post: 3rd February 2013, 02:34 PM
  3. Fog light bulb change...
    By Gairo in forum Astra
    Last Post: 16th July 2012, 09:38 AM
