Results 1 to 10 of 11
Thread: Engine Problem
    Member Stevie's Avatar
    Jun 2013
    80
    Engine Problem
    A couple weeks ago the engine management light came up on my car which was due to the lambda sensor... but my friend cleared it for me and it hasnt came back on since. But last night the orange light came on (car and a spanner) when I started the car, pushed my foot onto the accelerator but nothing at all, wouldnt even rev! Turned the car off then back on again and it worked fine again, is this something to be worried about?
      Member Dawkins_1's Avatar
      Feb 2013
      282
      The lambda sensor produces a voltage for the engine management depending on how rich or lean the mixture is, say if it's rich the higher the voltage, so the ecu puts less fuel in to the engine to compensate, vice versa if it's lean, if the lamda sensor is faulty it takes longer for the ecu to receive the signal off the relay, say a brand new one takes 0.1 of a second, a worn out one takes around 2 seconds, maybe more, get the code read and see which ones faulty, that's what it sounds like to me matey!
      Moderator Nick6425's Avatar
      Feb 2012
      334
      Do a pedal test mate and post up what codes come up.
      Jun 2013
      80
      Loads of codes have come up.... P0170, P1525, P1526, P1550.
      Member crazibrumi's Avatar
      Dec 2012
      Birmingham
      101
      2005 Vauxhall Astra 1.9 CDTI 150
      Liams hit the nail on the head. these are the fault codes
      P0170 Rich Exhaust C-30
      P0170 Lean Exhaust C-30
      P1525 Limp Home Position Error C-09
      P1526 Throttle Position Adaption Error C-09
      P1526 Throttle Position no Adaption C-09
      P1526 Limp Home Adaption Error C-09
      P1526 Lower Limit Adaption Error C-09
      P1550 Electronic Throttle Control Reduced Power C-09
      P1550 Electronic Throttle Control Forced Idle C-09
      P1550 Electronic Throttle Control Power Management C-09
      P1550 Electronic Throttle Control Engine Stop C-09
      Feb 2013
      282
      Glad to be of some help get the lambdas changed , clear the fault codes and your good to go matey
      Jun 2013
      80
      So you think changing the lambda will cure this problem mate? Its a fare bit of money for a decent lambda sensor replacement if this isnt the fault... the code p0170 hasnt exactly said its definatly the lambda.. its saying it could possibly be that or the MAF.. aswell as numerous other things..
      Moderator Jay-GSi's Avatar
      May 2012
      967
      Swap the maf with someones who works.. You tried unpluggin the maf when cars runnin?
      Jun 2013
      80
      Yeah unplugged it last night and its utter pants when off... so im guessing the MAF is fully working
      Feb 2013
      282
      The first thing you said was the eml come on due to the lambda, I only know this because I recognize the symptoms of it being a lambda by ruling all others out, just by seeing the symptoms you said I got an idea it's the lambda matey, 80 percent sure
  1. Meriva 1.7 Diesel Automatic engine noise problem
    By broonfaedoune in forum Meriva
    Last Post: 6th March 2015, 12:29 PM
  2. ANOTHER Problem with the VXR
    By Adam_SRI in forum Mechanical
    Last Post: 25th July 2013, 02:45 PM
  3. CID BIG problem
    By Zé Miguel Barbosa in forum Astra
    Last Post: 24th June 2012, 02:35 PM
