Did you reset ddm or just programmed something
With not matching codes car shouldn't start but if it started then something interesting is going on
DDM
Partnumber: 13170178
Alha Code: EL
Identifier: 0301
Software Version: OP1D 190000
PDM
Partnumber: 13170177
Alha Code: EN
Identifier: 0301
And why you can't use you original ddm?
Car starts normally and everything else works, just can't close windows via key fob. Old ddm was broken due to crash (doors was crashed and replaced).
I've checked with Tech2 and Comfort Close Status = Off
I can Comfort Close windows only if I push/hold the locking button on drivers doors panel and in that time Tech2 shows status for "Comfort Closing Driver's/Passenger's Windows = Active" .
But If I hold Locking button on any of my Remote keys, nothing happens.
Cheers.
dont think comfort close is something you can actually turn off... Comfort opening is though.. If its not comfort closing I would suspect the module... As I previously said I think, is there a setting in the DDM for 'Power Fold Mirrors' or 'Electric Mirrors' ?
In module with ident EL those two options for folding mirrors are set as "Not Available".
ok,
back to basics.. Is one touch set up.. ie when you press the window button down, you only have to touch it once, the same for going up.... press once then let go and it continues?
Ok back to basics, one touch works and windows goes normally down and up (was calibrated with push both down and up for few seconds). Also comfort open works via remote key. But comfort close works only via drivers panel if I hold Central Lock/Unlock button and does not operate if I hold lock button on remote key. And I don't have deadlock and rain sensor.
do you have access to another DDM and tech2?
