whats the difference between a blow off valve and a dump valve?
i though they where the same ?
is there any purpose of a dv or is it just for the ppppppppsssssssshhhhhh
It just dumps unmetered air to atmosphere instead of recirculating it
Plus it's mainly for the noise, my ssqv is fairly loud
thinking of getting one is that one you would recommend ?
Not unless you feel like getting it mapped in, look at a bailey dv26 twin piston or a Collins, I had the bailey on mine before the ssqv and it sounded nice but I wanted mine to dump really loud
Nick has a bailey he may part with
Got a Bailey dump valve on mine. Got a good sound to it. Got a Courtney hose for it to. Cost £56 for the hose. You have to blank off the standard valve or you will find ecu lamp on and loss of boost with a boost pressure trouble code popping up. Courtney recommended a twin piston valve. Take the vacuum pipe from the fuel pressure side regulator. T into that vacuum pipe. Works well on mine and sounds good.
where do you black off the standard one
Im running a collins and the oem recirc valve.. Mine aint that loud at all really
It's a pain in the arris you have to remove the intake on the turbo. Behind this there is a plate with three bolts in it. With this removed you will find a one pence will fit in the hole. Refit the dv and intake pipe and away you go. It's a pain. When you come to do it Pm your number and I will go through it more in detail.
Tbf mate I'm giving it second thoughts
Been reading up a a fair few say the corsa vxr don't like dump valves listing loads of problems
With this engine being similar I may give it a miss ???
Probably not blanked of the standard one!!
