Hi.. the gear changing is quite stiff.. but when car is driven for abit 20+mins it gets better. Car was due for gearbox oil change to be done in a few months could it be that.. also to note when the power steering pump was changed.. gears got alot stiffer wasnt going in.. but the mechanic adjusted something by the pump-gearbox end.. that got rid most of stiffness.. but since then started to get worse. Before the pas pump was changed i did notice gear stiffness ,
so i think could be either the linkages or just change the oil anyhow?
1.9cdti
