Just had a look at one at work. It seems to be spare for something else. It is not connected on this one too.
I'm trying to locate the fuel tank vent valve on my zafira b with the z16xep engine. As I get bad mpg and smell of fuel in the cab and have the fault code saying it has a problem and came across this connector which isn't attached to anything. It is attached behind air pipe and the wire disappears through bulkhead
Just out of curiosity, what car/ spec did you check thanks
i have a spare plug too mate. loads of people have it
i have one three mate...
They tend to make a fairly generic loom and then throw them in all variants, could be for a fluid level sensor or something similar, I wouldn't worry about it
