Field Remedy: 2579
Subject: Washer system, pump - Without function
Models: All
Complaint: Washer system without function.
Cause: Washer system fuse blown due to frozen washer fluid.
Production:
Remedy: In case of customer complaint perform the following checks prior washer pump replacement:
1. Check if the antifreezing concentrate is OK, respectively that the washer fluid/system is not frozen. If the concentrate is insufficient/the washer fluid is frozen, inform the customer about the correct mixture and/or refer to the owner manual.
2. If the washer fluid is frozen, defrost the washer system and fill-up washer system with washer fluid in correct mixture.
3. Check the function of the pump and nozzles of the washer system if necessary replace the washer system fuse. Note: A frozen pump will cause the fuse to blow through again.
