I need to know if 5 door rear seats are the same as 3 door? Thank you
I'm 99 percent sure the 5 door rear seats are the same as 3 door, only front seats differ between the two
The bench from a 3 door WILL fit into a 5 door car or an estate with some bodging but i'm not sure a 5 door bench will fit a 3 door car, the 5 door and estate variants have split benches with hinge mechanisms so that they flip forward to make the back seats lay flat, that isn't possible with a 3 door so double check first Steve
Whats the score then ? Have you been offered a 5 door interior ?
Basically I've been offered, two front design seats from a 3 door, and a set of design seat rears from a 5 door, dunno if they will fit now, why do they make feckin vauxhalls so complicated!The bench from a 3 door WILL fit into a 5 door car or an estate with some bodging but i'm not sure a 5 door bench will fit a 3 door car, the 5 door and estate variants have split benches with hinge mechanisms so that they flip forward to make the back seats lay flat, that isn't possible with a 3 door so double check first Steve
Pretty sure all of the above should fit matey sure chris willl be along soon to say yay or nay thought
Chris,The bench from a 3 door WILL fit into a 5 door car or an estate with some bodging but i'm not sure a 5 door bench will fit a 3 door car, the 5 door and estate variants have split benches with hinge mechanisms so that they flip forward to make the back seats lay flat, that isn't possible with a 3 door so double check first Steve
Does this mean 5 door rear seats are a straight swap in the estate?
