Field Remedy: 2204
Subject: Display, Check Control - Wrong indication "Check Coolant Level"
Models: Astra-H 2004...,Zafira-B 2005...
Complaint: Sometimes Check Control shows the message "Check Coolant Level" although the level is correct.
Cause: Temporary dropping of coolant level in the compensation tank during driving.
Production: .
Remedy: In case of customer complaint reprogramm the Programm Variant Configuration of the Front Zone Modul (UEC) with the new software update as of TIS 2000-DVD, version 91 or TIS2WEB.
Note: To ensure successful programming the engine type (Z19DT;DTH;DTJ;DTL)has to be selected correctly as a parameter from the variants.
