Results 1 to 2 of 2
    Member liamstears's Avatar
    Mar 2016
    Kent
    1
    Astra Mk5 2007 1.7cdti
    TID to BID Astra H
    Got an Astra H life model, 2007 with TID
    What I want to do is remove the stock headunit, fit a double din aftermarket headunit and change the TID to BID with trip computer
    Couple of questions
    Because I'm using an aftermarket headunit can I use any BID? Would it matter if its been paired with a different CD30 that I haven't got? So can I just grab any old used one off ebay?
    Also am I right thinking that the trip computer function is programmed into the BID itself and not the ECU or something else in the car? So for example if I was lucky enough to buy a BID with trip computer already enabled and has the correct fuel sender settings it would simply be just plug and play?
    Pecky can you chime in and help?
  1. Astra H BID Range issue
    By Tawe in forum Board Computer
    Last Post: 12th April 2020, 07:00 AM
  2. Undivorced BID
    By DJDC in forum Board Computer
    Last Post: 15th June 2019, 09:46 PM
  3. Meriva A swap TID with GID
    By alexhan in forum Meriva
    Last Post: 10th February 2019, 06:28 PM
  4. BID Range not quite right...
    By Bolter99 in forum Board Computer
    Last Post: 27th March 2018, 10:17 PM
tid to bid astra
tid to bid astra h
