the fakra is located at the bottom of the windscreen wedged between the dash and windscreen and the cable goes down under the speaker grill to the back of the unit
The speed pulse wire is basically a single wire that connects from pin 17 (abs pump) to pin 37 (radio plug). It's on my list of jobs to do. All it basically does is keep the signal while you drive through a tunnel. Where have you routed your fakra to?
