ok thanks i did come across that thread and had a read but my ident isnt listed so unsure
Hello,
I believe you can test the speedo with OP-Com. Go to IPC and then to Special Functions(or Measuring blocks), I'm not 100% sure but I can check.
Then you have possibility to test all lights on the speedo. You should find in the list "Park pilot light" and then "Start test".
If park pilot symbol appears on the dash I'm pretty sure that your IPC will support park pilot.
I hope I'm not mistaken.
Will check for correct menus in OP-Com and will post here.
Cheers,
Yea can try checking if light comes on with opcom
If still fancy can sell you parking module and wiring from it to rec
Looking at £40+pp
unfortunately my ipc doesnt support it i checked with opcom and nothing lights up
Oh bad news for you but in case if you need pdc parts what i got let me know
