Field Remedy: 2797
Subject: Driver Info Center - Missing menu functions
Models: Astra-J 2011
Complaint: Missing functions in DIC: No possibility to change units (Miles/kilometers, degrees Celsius/Fahrenheit) No possibility to reset day trip meter - still possible with cluster button No possibility to reset oil lifetime counter
Cause: Part of turn signal lever wiring harness removed from production content
Production: As of the following VIN's improved wiring harnesses have been implemented into production: EP - W0LPD8EG6B8080320 GLI - W0LPD6ED5BG110813
Remedy: In case of customer complaints do not replace any parts.
A modification kit is under development and will be made available
shortly.
This TSB will be updated accordingly.
