Results 1 to 6 of 6
    Member Kameleon1977's Avatar
    Sep 2015
    Nuneaton
    24
    Astra H 1.7 CDTI
    OP COM Radio DIVORCING PROBLEMS
    Hi guys,
    I have problem. I have 2 radios cdc30 and cdc40 not divorced from donors but I have codes for them.
    I can't marry or divorce them with OP COM.
    I am divorcing my original radio with no problem - I have display safe blinking on screen.
    Then I'm connecting one of the radios mentioned above and nothing :
    I can't remove code supplied with them, I can't marry my divorced screen with codes supplied
    Basically I don't know if its even possible with OP COM .
    Please help how to approach this problem.
      Member jpbroad1970's Avatar
      Aug 2015
      northants
      218
      Astra 1.6 VVT Elite 2011
      opcom can be a problem it has limitations as most on here would say. I divorced one of the radios by taking display out and deactivating code that way but its hit and miss ..... the only advice I can give is whats been given to me make sure all mid speed can and variant config are the same then try but tech 2 is best bet but aslong as stuff is all set the same opcom should do it but like I say its tempremental
      hope that helps a little
      john
      p.s. very unlikely to get opcom support on here as members prefer gen software and wont support pirate opcom etc ( sorry if yours is genuine )
      Sep 2015
      Nuneaton
      24
      Astra H 1.7 CDTI
      JP thank you. Anyone else?
      Aug 2015
      northants
      218
      I have used opcom a lot and have realised its limitations especially as you get to newer cars
      Check if security wait time isnt running,
      Otherwise should work by description you mentioned in 1st post
      Member manevni0's Avatar
      Mar 2015
      Sofia, Bulgaria
      177
      Opel Astra Mk5 1.7 DTH
      Check also for DTC in both - display and headunit modules. Clear them all, if there are any. Then if all MID-speed canbus options are matching between display and headunit and security wait time isn't running, you shouldn't have any problems with coding. I used OP-Com as well and I did this procedure couple of times without any issues.
  1. Changing cdr2005 radio/cd and display unit to cd30 radio/cd and display problems
    By gc1967 in forum Infotainment - ICE - In Car Entertainment
    Last Post: 5th March 2017, 09:11 AM
  2. Astra H Radio & Display Problems
    By john9893 in forum Astra
    Last Post: 21st January 2013, 10:51 PM
  3. 2748 - Radio CD30MP3 - Drive problems
    By pecky in forum Corsa D Technical Service Bulletins
    Last Post: 4th September 2011, 01:20 PM
opcom divorce radio
divorce saab radio opcom
divorce parts with opcom
opcom divorce display
opcome divorcing radio
vauxhall zafira display safe
vauxhall radio divorce screen
op com display safe
astra h radio how to divorce
op-com divorce
