Prepare control unit for removal (new SPS-function):
- This function is only required before removing an ECU from a
vehicle.
- Not all control units need to be prepared before removal.
- In TIS2Web, select "SPS" application and select "reprogram ECU".
After entering vehicle data and VIN, select the prepare control
unit for removal and follow the screen prompts.
Programming:
- Most new control units require programming. This function is also
used for reprogramming.
After entering vehicle data and VIN, select the appropriate
programming function and follow the screen prompts.
Configuration and Setup (New SPS-function):
- Some control units require a configuration and setup after
programming.
configuration and setup function and follow the screen prompts.
Immobilizer Learn (New SPS-function):
- The BCM and the ECM require an immobilizer learn after the
"configuration and setup" -function.
After entering vehicle data and VIN, select the "immobilizer learn
function" and follow the screen prompts.
