Pin assignment
PinColorWire sizeOptionFunction
6Black-White0.5.Rear Defog Switch Signal
10Black-Violet0.5.A/C Request Signal
11Yellow-Red0.5.Computer Command Ride Auto LED
12Green-Brown0.5NotchbackRear Park Assist LED Disable Signal
12Green-Brown0.5 NotchbackRear Park Assist LED Disable Signal
13Brown-White0.5 Rear electronic moduleFog Lamp Relay Control
16Red0.75.Battery Positive Voltage
17Black-Violet0.5.Hazard Switch Turn Flasher Control
18Brown-Blue0.5Not rear electronic moduleRear Window Wiper Switch Signal
19Gray-Yellow0.5.LED Dimming Signal
20Brown0.5.Ground
21Brown0.5.Ground
27Black0.5.Ignition Voltage
28Gray-Blue0.35/0.5.Front Fog Lamp Switch Signal
29Gray-Violet0.5.Instrument Panel Lamp Dimmer Switch Signal
31Gray-Green0.5NotchbackRear Park Assist Disable Signal
31Gray-Green0.5 NotchbackRear Park Assist Disable Signal
32Brown-Black0.35/0.5.Rear Fog Lamp Switch Signal
33Yellow0.5.Headlamp Low Beam
34Green0.5.Low Speed GMLAN Serial Data
35Green0.5.Low Speed GMLAN Serial Data
36Brown-Yellow0.5.Headlamp Switch Low Reference
37Gray-Green0.5.Headlamp Switch Park Lamp Signal
38Brown-White0.5Open & StartDoor Lock Lock/Unlock Signal
38Brown-White0.5 Open & Start Rear electronic moduleDoor Lock Lock/Unlock Signal
39Black-Brown0.5.Tire Inflation Monitor Reset Switch Signal
40Green-White0.5.Hazard Switch Signal
41Yellow-Black0.5.Computer Command Ride Auto Switch Signal
42Brown-White0.5.Rear Defog Relay Control
