    Member hal752's Avatar
    Mar 2015
    St Helens
    4
    Astra H
    BID retrofit Astra H
    Good Evening all.
    I've posted on here before in relation to a BID I retrofitted into my 58 plate astra H 1.6 Petrol.
    I originally had it coded in with a tech 2 device which fixed my strange readings of 45 MPG with a combined run for my 1.6 petrol. The only issue I had was that the range was completely wrong. When my tank was empty it would say I had 200 miles left in it =( I felt that the reason for this is that my BID was reset when I had half a tank of petrol so I presumed that it felt that half a tank was a full tank if you get me?
    I left it for a while until recently I decided to have ago at it myself with a opcom unit. I changed the code to 10 which sent my mpg to 45 mpg again.. Obviously this isnt true. so im going to change it back to 2. But beforeI did that I was wondering if anyone could guide me in resetting the BID so it showed a full tank as a full tank? I have a opcom so I would be doing it myself
    Thank you
      Member jpbroad1970's Avatar
      Aug 2015
      northants
      218
      Astra 1.6 VVT Elite 2011
      morning
      I would have said code 10 would be correct , I get 47-48 mpg or more if careful on a run with my 1.6 twinport 38mpg tootling back and forth to work about 7 miles each way, try setting it to code 10 and resetting all the trip figures and running for a week or 2 see if it settles , your fuel level inaccuracy would be down to the fuel sender type that is set with the display code. sure someone will put me right if my advice is wrong
      john
      Correct index is 10
      Index 2 is for different fuel sensor which isnt fitted to your car as its out of fitting since nearly end of 2004
  1. BID zafira b which index code to program
    By harvard in forum Board Computer
    Last Post: 12th April 2020, 07:02 AM
  2. Astra H BID Range issue
    By Tawe in forum Board Computer
    Last Post: 12th April 2020, 07:00 AM
  3. Undivorced BID
    By DJDC in forum Board Computer
    Last Post: 15th June 2019, 09:46 PM
  4. BID Range not quite right...
    By Bolter99 in forum Board Computer
    Last Post: 27th March 2018, 10:17 PM
