Good Evening all.
I've posted on here before in relation to a BID I retrofitted into my 58 plate astra H 1.6 Petrol.
I originally had it coded in with a tech 2 device which fixed my strange readings of 45 MPG with a combined run for my 1.6 petrol. The only issue I had was that the range was completely wrong. When my tank was empty it would say I had 200 miles left in it =( I felt that the reason for this is that my BID was reset when I had half a tank of petrol so I presumed that it felt that half a tank was a full tank if you get me?
I left it for a while until recently I decided to have ago at it myself with a opcom unit. I changed the code to 10 which sent my mpg to 45 mpg again.. Obviously this isnt true. so im going to change it back to 2. But beforeI did that I was wondering if anyone could guide me in resetting the BID so it showed a full tank as a full tank? I have a opcom so I would be doing it myself
Thank you
