Using NEO Hex Editor, on line 00000480, 000004c0 & 00000500 I get the code 5903
Can anyone confirm as this is the first one I have done?
Thanks again
Hello all,
Is anyone able to get the car pass from the dump I have..
ECU was EDC16C9 and the EEPROM dump is from a ST95320 I believe
EDC16C9 Test EEPROM ST95320.zip
Thanks in advance
Thanks again
I would confirm that, cant get it to load on mine but comparing to a known good one that sequence looks correct
Is this any better?
http://www.shokstudios.com/ST95320
i would have been expecting a different eprom to to be honest.. a 95160
I meant couldnt get it to go through on the decoder, rejected it...
Opened it manually in hex editor..
Ah ok, fair enough.
I took the name 95320 from K-Tag, which I used to read it with, this could be wrong. I did not actually find it on the board.
