Just look on here http://www.diagnostics.org.uk/help/booking/ click a time and fill in the form. Address details are sent automatically once the booking is approved.
Hi Pecky,
Can you please contact with ref to activating OBC on my Corsa D
Thanks for the reply.
I did try thee booking link but it only offered evening hours
I work at A1 Clutches at Shareshill and the car is there 8.00 - 5.30 Mon - Fri and 8.30 - 3.30 Sat
Is there any way you can carry out the work during those times
Tony 01922 411700
Hi, same problem here, 57 Astra 1.7, no BC function, display got time and temp and 2 further lines, should be OK to be activated. How can I get in touch, I only up the M54, J6. Thanks in advance.
Please click on the Tab at the top of the page marked 'Bookings' to get through to the area you need.
Can I ask to list the steps you follow to enable the BC on a vauxhall Corsa D? I have the gid screen and access to tech2.
Diagnostics -> Year - -> Model -> Infotaim=nment system -> DIS -> Programing -> Program code index -> set number of index with BC support.
Diagnostics -> Year -> Model -> Infotaim=nment system -> DIS -> Programing -> Program variant configuration - set "Board computer" to "Present".
Usually, to enable BC you encrease number of existing index by 1 (as example, set 009 if existing is 008). You also can find correct code index in TIS
Thanks mate, much appreciated.Diagnostics -> Year - -> Model -> Infotaim=nment system -> DIS -> Programing -> Program code index -> set number of index with BC support.
Can you list the steps to enable the cruise control as well please.
Why are you so lasy to use google?
Diagnostics -> Year -> Model -> Engine -> ECU model -> Programing -> Program variant configuration - set "Cruise Control" to "Present"
Diagnostics -> Year -> Model -> Body -> CIM -> Programing -> Program variant configuration - set "Cruise Control" to "Present"
Diagnostics -> Year -> Model -> Body -> IPC -> Programing -> Program variant configuration - set "Cruise Control" to "Present"
