well hopefully all goes well tomorrow would really like the cd40 usb to work
right have put original head unit back in with display and all coded ok, I have a friend who apparently still has tech 2 so will try and add my Bluetooth to original radio. would like the cd40 usb to work though but it hasn't been divorced ....what would be the options for that be an eeprom reflash if so where would I get a file for that or do I just meddle with the file I get off eeprom, a bit of help on that would be appreciated
just to list what I have
cd40usb from corsa code 9517
uhp4 module from same corsa code 9517
both work when put together
gid coded 9517 (but doesn't appear to work with the cd40) this may just be crappy opcom as it doesn't list cd40usb hence the tech2 trip
cd30mp3 coded 9517
cd30 coded to 0957
just goes to show sometimes cutting corners costs dearly
just thinking out loud as I have the code for the cd40usb will I just be able to reset that with the tech2 on friday(the day of reckoning lol) and then reprogram with the same code to pick up the uhp4 module or if I leave the uhp connected at same time will it clear that too bearing in mind the gid isn't programming at this point so will just leave that unpaired until radio is unpaired ( right or wrong )
sorry for so many questions
any more ideas guidance would be much appreciated
john
Well couldn't program cd40 as tech 2 was only updated to 2011 and couldn't even pair uhp4 with my head unit with code as its from 2013 so as I see it update tech2 or get cd40 code dump and work out how to put back to factory through dump or get uhp4 wiped......which is the best option?????
Update tech2 will take less time than fidling with dumps
Thanks is that just a case of putting an updated card in
Yep if you got card already updated, if not connect tech2 to pc and update
Haven't got laptop software so was looking at an updated card on ebay , its an old colleagues one so just need easy solution
If you can connect tech2 to laptop than no problems at all
send me your email and i will send you soft for programming tech2 via com port aswell opel v177 bin file
You need too?
