Results 1 to 3 of 3
    1,340
    CD60 Navi upgrade from cd30
    Good evening all
    Fitting a cd60 into a corsa which previously had only a cd30 installed.
    Sat Nav not working.... GPS is good, satellites seen are good but just doesnt move.
    If this the same issue with the loom missing a vehicle speed signal to get it running properly as what was seen with the dvd100 a few years ago on this forum?
      1,340
      bumpage..
      going to my mates house tomorrow to try this. Not sure what pin type they use on this ABS plug, so taking my entire collection with me... Maybe already has a pin in it...
      1,340
      Following up on this..
      It does indeed require a 'wake up' signal to pin37 from the ABS unit.. I've not seen one of these type of plugs before and couldnt get a pin inserted into it. Think the whole plug needs to come apart to get to the secondary lock..
      Managed to get a cable to the pin though through other methods (whistle lol) but can not measure a voltage on it whilst moving. Same test done on my car and the same. So it is a signal rather than a measureable voltage..
      So either my connection is not making good on pin3 abs or the ABS pump doesnt support an output on it..
      The investigation continues..
  1. Corsa d cd60 navi
    By M4rcx in forum Corsa
    Last Post: 7th November 2020, 09:25 PM
  2. EEPROM CD60 Navi 24c32 Delphi Grunding Ident AL Corsa D
    By nicos in forum Infotainment - ICE - In Car Entertainment
    Last Post: 11th April 2017, 05:49 AM
  3. Cd60 navi
    By Smart74 in forum Infotainment - ICE - In Car Entertainment
    Last Post: 1st January 2017, 08:19 PM
  4. Cd60 navi
    By Nels77 in forum Decoding
    Last Post: 27th May 2013, 10:43 PM
