No they wont be 0
No they wont be 0
Oh ok so what will I need to do to get th fitted and working? Sorry for the questions but seem to know your stuff and no one else has replied...
No worries glad to help
If you got tools you can remove eeprom and read it than it can be set to mileage what you want or anything under 100 miles and you can give a try with opcom
Also its recomended to use new eeprom
If dont wanna do it than first thing is to contact pecky if he wont take a job than there is couple of blokes who can do it
Ok I'm lost with eeprom stuff lol so think it's gonna be see if Pecky can help. Does a tech2 reset UEC/fusebox need programming to my car?
Yes it will need programming
Later will check wiring for rain sensor
hi this is what I did but just used an ignition live not the rec wire
Pin 1 Black, Ignition live via pin 7 of XR4 on the REC which is the main right connector as you look at it face on
Pin 2 Brown, Earth
Pin 3 Green, To pin 54 connector XE2 of the UEC under the bonnet which is the connector under the fuse box at the back facing one way rather than the 2 facing the other
the mirror just uses the live n earth
You will fallow this guide or still fancy wiring diagrams didnt had a time yesterday was on phone with tsb sorting out why they blocked transaction, terrible evening whren you try to buy something at 1k price bank wants to check if its genuine or fraudsters doing it
But in end had a laught anyway asked them if they will let me buy a milk in morning
Would still like the diagrams please. All banks are jokes I had similar problem not to long ago lol
Would I also need to upgrade REC for rain sensor? Thanks
