Hi there,
I've been having problems with towing electrics on our '56 Zafira B. The towing electrics that were fitted originally were causing major problems with the brake lights staying on, the immobiliser and the headlights but this was caused by bad wiring into the Canbus system so I had it all removed and this cured all the problems.
I have purchased instead the genuine Vauxhall dedicated 7 pin towing electrics kit and plugged it directly into the REC as instructed. The problem now is that the lights on my trailer don't work properly. The R/H indicator works but everything else seems to just 'strobe'.
What I need to know, if anyone can tell me, is if this is being caused by my LED trailer lights (because they don't draw as much current as normal bulbs) or if it is because there is something in the REC which needs enabling with Tech2 to tell it that the new wiring has been fitted, and if so how do I go about it.
If anyone can shed any light on this it would be much appreciated.
