Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Member manevni0's Avatar
    Mar 2015
    Sofia, Bulgaria
    177
    Opel Astra Mk5 1.7 DTH
    Congrats for result! It is nice to see that somebody started with questions and make everything till the end stage - operational retrofit.
    • #12
      Member zdravko.primorac's Avatar
      Nov 2014
      Mostar, BiH
      57
      Astra H
      Here is picture of proof how it works.
      I like it very much
    • #13
      Nov 2014
      Mostar, BiH
      57
      Astra H
      Update about the mirror.
      Didnt took a lot of the pictures as my baby sleeps and do it very quickly.
      As I changed all interior led-s to white.
      The yellow/amber led in the rearview mirror was bothering me.
      I decided to change it to white but problem was how to open the mirror housing and not to damage it.
      I read few posts on some vaux forums and as I can remember some of the members tried but the mirror housing was badly damaged.
      So I carefully approached to it.
      As I work in PC/Laptop repair shop I decided to use old credit card (in my case it was expired auto club card).
      Here are the pictures so, you will get it as soon you see the pictures.
      Old led.
      Its 6mm one.
      I put 2x3mm and it works fine.
    • #14
      Member Mihai Swz's Avatar
      Oct 2019
      Romania
      1
      Opel Astra H
      Quote Originally Posted by zdravko.primorac View Post
      I bought a whole set of this parts, with the wiring.
      It has:
      1. Light switch with "AUTO" position
      2. Rear view mirror dimmable, with light sensor and ambi light led
      3. Rain sensor
      4. Plastic covers for sensor and mirror base
      5. Whole wiring for it
      So, I already fitted light switch and it works just as the old before.
      I fitted new rear view mirror too.
      I used old base (metal plate that is glued to windscreen).
      Cleaned it and glued using Loctite 319.
      Removing base is a bit pain and risk to break/crack windscreen.
      So as its summer now and here the temperatures are almost 40 every day.
      I parked the car on the sunlight for 3-4 hours.
      And rotating the base left and right it came off in a minute.
      Also the base had to be moved up, closer to the roof, so that plastic covers can be fitted properly and hide all the cables.
      So, now I am on wiring.
      Auto dimming mirror has 2 wires.
      Brown and black.
      So, I suppose brown is + and black is -
      Rain sensor has 3 wires.
      Brown, black and green.
      I suppose brown is + and black is - and the green is some sort of signal.
      Can someone please help me with this?
      I would like to make rain sensor functional.
      So need to know where the wires ending too.
      In which connector they go?
      As I can see, they go down the A pillar in the footwell.
      Any advise and suggestion are welcome.
ID:	2398Click image for larger version.
ID:	2399Click image for larger version.
ID:	2400Click image for larger version.
      Hello guys ! Hope somebody is still around on this topic to answer a few of my questions regarding how to retrofit rain sensor/light sensor and dimmable mirror!I want to change the windshiled that has already the rain sensor from another car ( i think it has the light sensor,it has a auto light switch , i ve uploaded a photo with the windshield ) and the dimmable mirror with ambient light and i m not sure how to connect them/wire configuration.Is it possible for my car to have already the wires in some socket up under the reading lights panel(at least for the rain sensor) , for the dimmable mirror i know that the reverse light wire in the REC i don t have it,i ve checked pin 7 of the green socket . The car came from the factory with the big sunroof version so almost all the connection wires i have them,for the heated seats,cruise control clutch switch socket,not for AFL lights and not for PEPS (passive entry/start).The sensor has three wires brown,black and green and the mirror 4 wires from the mirror in the socket and 2 wires from the socket brown and black . Can somebody say where this wires they need to be connected "as OEM as possible" ? I ve uploaded 4 photos with the windshield(rain sensor and you to say to me if it has light sensor as well) the REC of the car and 2 photos with a socket under the reading lights panel,there are 6 wires going in from the left side and 5 coming out from the right side) .Is it possible for one of these 6 wires in the socket to be the rain sensor wire?Thanks
    • #15
      Member n0tiert's Avatar
      Aug 2016
      Frankfurt
      129
      Astra H
      Rainsensor > Regensensor
      Elektochromatischer Spiegel > Mirror
      4PIN Molex:
      #1 black +12V Ignition > Rainsensor / Mirror #1
      #2 Brown Ground > Rainsensor / Mirror #2
      #3 Green XE2 Can-Bus Signal > Rainsensor #3
      #4 Grey Timer Signal > Mirror #3
      Astra H Caravan Z14XEP 18" OPC Line Rims
      https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
    • #16
      Member George McDuke's Avatar
      Nov 2019
      BL
      5
      Astra H Sedan (L69)
      Did you got wiring or you do it by yourself?
    • #17
      Aug 2016
      Frankfurt
      129
      Astra H
      Quote Originally Posted by George McDuke View Post
      I've done it myself. I checked wiring diagram and build my own wire.
      That are my project Images, there is no 4pin Molex in Cars
      Of course you need to change the front window.
    • #18
      Nov 2019
      BL
      5
      Astra H Sedan (L69)
      Nice work, can you share more info and pictures regard work?
      Witch model year is yours astra? Mine is 2009. I am curious where you connected wires? Did you got already preinstalled OEM wires, so you just connect them to mirror and sensor (and enable all via Tec2 or OP-COM) or you do wiring from UEC to sensor and mirror?
      Where do you pickup 12V? On mine Astra lighter is not option because it has permanent + (still looking for on ignition +, but I would like to do it OEM as much as possible).
      All hints, diagrams and pictures are welcomed and appreciated.
      Best regards,
      George
    • #19
      Aug 2016
      Frankfurt
      129
      Astra H
      no preinstalled wires at all, my Astra Z14XEP 2006 Estate was naked, upper Image from XE2 shows all you need.
      UEC #X2
      Pin #38 is 12v+ Ignition
      Pin #54 is CanBus Signal to Rainsensor
      4PIN Molex:
      #1 black +12V Ignition from XE2 #38 > Rainsensor / Mirror #1
      #3 Green XE2 Can-Bus Signal from XE2 #54 > Rainsensor #3
      Retrofitted: AFL, Rear elect.Windows, TPM, DDS, HSA, Recaro Leather, Seat Heat, complete OPC Line all bunch a stuff...
      Current Status: fitting in Z20LEH
    • #20
      Member Lakey's Avatar
      Dec 2021
      London
      2
      Astra h mk5 vxr
      connectors for mirror and rain sensor
      Quote Originally Posted by n0tiert View Post
      UEC #X2
      4PIN Molex:
      where did you get the connectors for the mirror and rain sensor to build your leads?
  1. Auto lights, wipers, dimming mirror
    By Jay123 in forum Electrical
    Last Post: 10th October 2016, 04:00 PM
  2. Replies: 1
    Last Post: 1st December 2015, 05:57 PM
https:www.diagnostics.org.ukshowthread.php3912-Retrofit-auto-dimming-mirror-and-rain-sensor
astra h dimming mirror
astra h auto lights wipers retrofit
astra h rain sensor wiring
astra h rain sensor
astra h retrofit auto dim mirror
wiring mirror astra h
astra h auto dim mirror retrofitasrra h retrofit dim mirrorcable rain sensor astra hastra h rain sensor tech 2https:diagnostics.org.ukshowthread.php3912-Retrofit-auto-dimming-mirror-and-rain-sensorpage2astra h auto dimming mirror retrofitzafira b rain sensor wiringastra rear view mirror wiringreplace dimming mirror sensor opel zafira bzafira tourer auto dim mirror retrofithow to conect light sensitiv mirror astra jHow to instal Dimming light sensitiv mirror astra jhttps:www.diagnostics.org.ukshowthread.php3912-Retrofit-auto-dimming-mirror-and-rain-sensorpage2https:diagnostics.org.ukshowthread.php3912-Retrofit-auto-dimming-mirror-and-rain-sensorwiring diagram opel astra j rain sensorretro fit auto dim rear view mirror to astra hastra h retrofit rain sensorfit in astra rain sensor
