Field Remedy: 2130
Subject: Manual transmission - Clutch does not disengage and/or gears hard to engage
Models: All
Complaint: Clutch does not disengage and /or gears hard to engage.
Cause: Toothing of the input shaft not greased (either forgotten in production or after clutch replacement in service).
Production:
Remedy: In case of customer complaint check first the greasing of the input shaft.
If necessary thinly grease gear teeth of input shaft with grease (partnumber: 90397024 / cataloguenumber: 19 48 568).
Please do not change any other parts.
