I found a upa j tag for the clocks just not tried it out yet.
Zif socket couple of wires and it saves you time soldering de soldering eeprom every time
yeah? that would be handy... lemme know once you've got it all figured out
I have a try Iv got a few sets of clocks about its just pics of were to connect and what pins on upa, etc
thread revival!
how did the jtag option go?
never bother with it mate as most I do I just rechip now
soulman you got me going now any one built a power connector for clocks using original loom chopped up, I've built a custom one for vxr ecus but might build one of these aswell.
here's my ecu flasher.
with the clocks it needs to be woken up from the cim unit....
I have a test bench which has the cim unit, clocks, radio and display connected.. plug 'limbs' on it ready to plug in my other leads like dab and bluetooth.. still need to make up other leads for ddm, pdm and others...
l
may knock up one similar to yours for ecu clearing as well..
OK do you no what pin I need,
found ground, 12v+ high and low speed can bus, I'd like to get it so I can reset them on the bench with tech 2.
I've got a complete Astra H on my bench loom with every programmable module, even got a CIM with a key to do the ign on and off when necessary to SPS sometimes.
