PB UQ etc
Give us a vin to which zaffy it will go and will give you idents whats fits by epc
Hi can anyone tell me the ident code for a set of these clocks? Any help would be much appreciated!! Found a few but sellers don't know if there off the sri model. Thanks
PB UQ etc
I've only got the 1.9cdti life model been adding a few things and wanted to see if the sport button would work. I know you need the sri clocks. I got given the hazard switch with park pilot and sport mode. So it's a 50/50 if it works or am I wrong on that?
Ok will find out what ident you need
Are you going to install park pilot too?
FQ FW FG idents will work with sport and park pilot
Yeah gonna install park pilot I'm looking at the pdc at the moment seen it for £20 and the loom with sensors for £35. Thanks for that it's a great help. Any ideas about the windscreen for sight and light? Got all other parts
Well if you gonna replace windscreen than its much simpler if not you need to find way how to make it look ok
In astra its not that bad bit of tinting film but in zaffy from memory sensor was nearly in middle of windscreen so could look not as good as wanted
Managed to sort out the windscreen looks good but have a problem. Think I need to change my UEC fusebox as the option isn't available when I tried to get it programmed. I've found one from and elite that had sight and light but the only thing is its a petrol and im not to sure if the fusebox will work in my diesel?
