Have seen one of these there was bcm shorting to ground after some connection to it
I have installed a cd30 mp3 with gid to my corsa life and had it tech 2ed in
Im getting b3750 board computer switch circuit open dtc coming up on the tech 2.
Has anyone got any ideas why im getting it and how it can be sorted
what year, engine type, gearbox type. what display you had in the past. questions based on info required by tis to find out what is this code all about.
B3750 is not in the error list of the GID, sorry.
Maybe, but is not in the list. Also I do not know what you refer to board computer, there is no hardware device in your corsa d called board computer. That is actually a software function. Which sits in the display unit, called TID, MID, GID, CID, depends what you have.
Thats a bcm code not a display
That's what I said in my first post
I installed a gid changed the code index on tech 2 programmed it in.
After I was getting the dtc on the tech 2 b3750 board computer circuit open.
Yes this is in the bcm setting on the tech 2
Sorry for any confusion
As i told in my first replay bcm is shorting somwhere to ground
Any retrofitting done so far?
And if possible double check connector at gid side in case if any of pins bend down
