Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 37
Thread: Signum codes
    Member dave234's Avatar
    Mar 2015
    Bristol
    28
    Signum 06 v6 CDTI
    Signum codes
    HI All
    I have one problem that will be sorted by soulman - CIM, however When the car is hot (90 degrees) and im in traffic the car shudders and revs to 1k and the EML light comes on. If i feel it coming on and rev the engine and it stops. The DTC reports missfire detected in cylinder 1 and 2. 1 is present with EML on and 2 is not present.
    If i put my foot on the brake it does not stop the EML coming on but the revs drop to usual tick over. The other odd thing is i noticed it only really happened when the car trip says i have about 45miles left or when it goes into the fuel gauge between the last white bar and the first red.
    i have also started using premium diesel and it seems smother.
    I had a DTC for the fuel level sender and sometimes it takes sometime to pick up more fuel has gone in on both the gauge and the range. IS the car struggling for fuel as the gauge is off/crap in the tank? as if i stick some derv in it behaviours as it should do
    I am also getting a range of other errors. They are below
    P0100 - Mass Or Volume Air Flow Circuit Low Input
    (03) - Not present
    P0340 - Camshaft Position Sensor Circuit Range/Performance
    (2C) - Not present
    P0560 - System Voltage Low Input
    (03) - Not present
    P1639 - 5V Reference Circuit 3 Low Voltage
    (03) - Not present
    P1625 - Main Relay Circuit Low Voltage
    (02) - Not present
    P0301 - Cylinder 1 Misfire Detected
    (00) - Not present
    P0302 - Cylinder 2 Misfire Detected
    (00) - Not present
    P0305 - Cylinder 5 Misfire Detected
    (00) - Not present
    P0400 - Exhaust Gas Recirculation Flow Excessive
    (11) - Not present
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (12) - Not present
    P0409 - Exhaust Gas Recirculation Circuit Range/Performance (Closed Valve)
    (63) - Not present
    P0235 - Boost Pressure Control Circuit Negative Deviation
    (12) - Not present
    P0235 - Boost Pressure Control Circuit Positive Deviation
    (11) - Not present
    P0409 - Exhaust Gas Recirculation Circuit Range/Performance (Open Valve)
    (62) - Not present
    P1530 - A/C Relay Voltage Low
    (06) - Not present
    P0615 - Starter Relay Circuit Low Voltage
    (06) - Not present
    P0460 - Tank Level Sensor Circuit High Input
    (07) - Not present
    U2103 - CAN-Bus Node no Communication
    (70) - Not present
    P0638 - Throttle Valve Stuck Closed
    (63) - Not present
    P0638 - Throttle Valve Stuck Open
    (62) - Not present
    P1900 - Diesel Particulate Filter Overloaded
    (55) - Not present
    P0425 - Exhaust Gas Temperature Sensor 1 Temperature not Plausible
    (52) - Not present
    P0235 - Guide Vane Control Rod Position Sensor Range/Performance (Stuck Closed)
    (63) - Not present
    P0235 - Guide Vane Control Rod Position Sensor Range/Performance (Stuck Open)
    (62) - Not present
    P1571 - Stop Lamp Switch Circuit Fault
    (5A) - Not present
    P0571 - Stop Lamp Switch Circuit Fault
    (04) - Not present
    If i clear them i get the below straight away as soon as i start the engine
    (62) - Not present
    (63) - Not present
    (63) - Not present
    (62) - Not present
    Its a 06 3.0 V6 CDTI Signum with 89k on it.
    Please help. I have only had it a month and have been so stressed i ended up in hospital with a suspect heartattack a week ago. I really like this car
  1. Signum - TC/AFL/PAS
    By dave234 in forum Vectra
    Last Post: 6th May 2015, 05:53 PM
  2. signum
    By v6si in forum Vectra
    Last Post: 5th October 2014, 09:39 PM
  3. Signum build
    By Brett Sutton in forum Vectra
    Last Post: 8th July 2012, 07:36 PM
signum p0571
signum p1625 which one is the main relay
3.0 v6 cdti vectra cylinder 5 miss fire
opel signum code p0235
vectra 3 litre diesel p0235
vectra 3.0 cdti misfire cylinder no.1
p0638 stuck closed vauxhall
https:diagnostics.org.ukshowthread.php3653-Signum-codes
