Results 1 to 7 of 7
Hybrid View
    Member Salman Irtiza's Avatar
    Mar 2015
    Romford, Essex
    3
    vauxhall zafira 2011
    Cruise Control Dash light
    I just had cruise control fitted on my 2011 Zafira exclusiv model by a Vauxhall specialist.
    However, there is no light on the dash when cruise control is on.
    He told me that he did check this but because this car didn't come with cruise control out of the factory they didn't put a light for it.
    Can anyone confirm if this is correct?
    Also when I turn the ignition and all dash lights come on briefly, I do not see a cruise control light there.
  2. #2
    Yes thats correct, when had fitted to my astra had same no dash light
  3. #3
    Member manevni0's Avatar
    Mar 2015
    Sofia, Bulgaria
    177
    Opel Astra Mk5 1.7 DTH
    The same result when I retrofitted my cruise control - fuction is fully operational itself, but no light on dashboard, when acive.
  4. #4
    Mar 2015
    Romford, Essex
    3
    ok that puts my mind at ease, thx guys...
  5. #5
    If you really wont showing it swap clocks,
    I had to do it anyway as park pilot wasn't working with mine clocks but after I swapped them to compatible ones got pdc working aswell cruise light showing
  6. #6
    Member amikot's Avatar
    Sep 2022
    England
    2
    Zafira A 1.6
    So, how it's with swapping clocks in Zafira A ?
    Do I need to log off old ones from ECU and log new ones in?
    I have also Corsa D and there you can't just swap the clocks - you need to log them off and log new ones in.
  7. #7
    Member Huxtable92's Avatar
    Mar 2024
    Paris
    1
    Corsa F
    Why don't you consider adding some flair to your dash by installing a custom LED light to indicate cruise control activation? It's a simple DIY project that can add a touch of uniqueness to your ride.
  1. Zafira a cruise control dash lighr
    By GFOUDIS in forum Cruise Control
    Last Post: 15th February 2024, 05:51 PM
  2. Zafira a z16xe cruise control light
    By GFOUDIS in forum Zafira
    Last Post: 23rd July 2019, 12:49 PM
  3. Cruise Control Dash Light
    By Skyman in forum Cruise Control
    Last Post: 23rd April 2017, 09:18 PM
  4. Cold starting and traction control light
    By Adam Brazier in forum Astra
    Last Post: 5th November 2016, 11:36 AM
  5. Astra MK5 VXR Traction Control Light Always On
    By Kurrazyman in forum Astra
    Last Post: 17th October 2014, 04:07 PM
astra h cruise control no light on dash
