Don't seem to having much luck retro fitting at the moment!
Enabled check control on the UEC and CID (No sensors fitted), bulb failure working as it should and low washer fluid being displayed as you would expect but no low engine coolant showing. I've found the plug and doesn't appear to be shorting so why would it not display a warning?
Is there a fuse for the circuit?
Thanks,
Rob
