Thanks! Not sure how I missed that thread!
There was another one but didnt found it at moment
My advise is to get more things retrofitted and than visit someone with tech2
Was out in my Signum on the weekend (factory CD70 and check control), low coolant light came on the dash but no message on the CID! Which got me thinking, I updated the firmware on the CD70 (20.06.2008 version) 4 weeks ago. I'm sure I used to get the message on the CID as well.
I also updated the CD70 firmware (10.10.2007 version) on the Zafira at the same time (before I enabled check control). Is there anyway it could be related to this? It seems a coincidence that both CID's are not showing the message after updating the CD70 firmware.
check to see if 'check control' is enabled in the variant config of the display
Cd70 has nothing to do with check control as it will function without radio too
If you got warning on dash uec side is ok
Its only your cid which is not showing it
