Thanks, guess it would be easier to check the UEC end first.
Will check wiring tonight
What you used to activate check control?
As on quick look it seems to be transmited to screen by can bus
OPCOM (3-4 years old). Is there a possibility that it's not changing the variant correctly?
If it uses can-bus and the washer fluid is working then the UEC must be compatible?
Yes it looks like opcom messed it up, im not opcom user so cant say 100% but i think i saw somwhere on forum that opcom can mess it up
Also getting a this fault code on the EHU if it could be related?
U2206 - CAN-Bus No Communication with DIS (Display)
(00) - Not present
Yep its cid side
That fault is not present if you had screen removed etc it can be stored nothing to worry about
Thanks, could it be possible that OPCOM is not programming the CID correctly? Although it is displaying low washer fluid.
It messes eeprom sata
Didn't found post what i was looking for but there is similar
http://www.diagnostics.org.uk/help/s...Control-Op-Com
