Not gone over yet mate car is 30 miles away from me should be going about 12ish will be taking decoding gear with me this time.
How's it going? Got it running?
Good man
Replacing bcm sorted it?
Yer mate didn't have to sps it just programed it in and then coded keys back to the car job done.
Do you have pic of which eeprom it is there are to on the back but they been sprayed with a clear film and can't make the numbers out.
Sorry don't have any pictures but will double check on ext hdd
Here the bcm iv got only 2 on this side
I have fixed this with opcom v1.45 using software 100219a and vauxcom 120309a sadly it's a temporary fix on a few models it does return unless a bcm update is done by tech2 or mdi I believe.Just been to look at a corsa, was told just needed key programing and when I got there it was faulty bcm due to flat battery.
Anyway tried sps reprograming it but no joy thinking about it now should of tried replace option, but advised them to get a new bcm, this the 4th time iv came across this now.
- Reset IPC
- Reset BCM
- REPORGRAM TRANSPONDER KEY
- RESET SDM
- REMOVE KEY FROM CAR FOR 30SECONDS
- PUT KEY BACK TO SHOW DASH LIGHTS
- PROGRAM IPC
- PROGRAM BCM INSTALLED
- PROGRAM SDM
- READ AND DELETE FAULT CODES
- REMOVE KEY FROM CAR FOR 30 SECONDS
- START CAR PROVIDING BATTERY IS AT ENOUGH VOLTAGE
