Hi Soulman did you get any joy with op com programming of the twin audio system
Yes uhp4 is bluetooth
To retrofit it you need this kit
http://www.diagnostics.org.uk/shop/r...-uhp4-kit.html
And programming
not had a chance.. Got a bit of time now, lemme fire up laptop and reinstall opcom (had to fit a temp harddrive as the SSD died)
How did it go Soulman , did your op com have the twin audio option
Mare will drop off his opcom tonight will check it for you
thanks for picking this one up, went to the room to have a play and copy opcom across and got sidetracked Next thing I know I'm changing two flywheels/clutches and 3 steering racks/subframes!
No probs mate
I love changing racks on mk5, on wifes mk5 its leaking and has play so will be droping frame too
Clutch isnt that bad if you got spare hands to help
these are vectra's... Did two of them side by side at the same time
Only one good thing on C's are they got more room in bay but dropping frame down sometimes becomes pain in ...
Not done yet on vectra but looks like its same as mk5
