Found this kit on ebay...
CAR KIT Side Rear View Rearview Mirror Folding Closer System Intelligent DU
http://pages.ebay.com/link/?nav=item...749135&alt=web
Any thoughts or advice?
also would it be possible to run the open/close signal from the deadlock signal?
how would I go about doing that?
bumperty bump bump
Why not go for oem route?
Original power folding mirrors press button and they folds
Anyway you need to fit folding mirrors and all whats left to add will be new window switch with pf mirrors button and some missing wiring
I just seen this kit and wondered if it was possible to make them auto fold when locking the car. While also having the function of the button.
Allright, seems that kit can do it only cant tell you much as havent seen what is required to run kit connection etc as most off can bus systems runs all switches etc by applying ground not positive voltage like in older cars. Thats one of the reasons why can bus was introduced to save on wiring
Like before you needed to run wire to switch and back now only from switch
Well kit is only £7 so give a try if help with wiring is needed will try my best to help
Bought this ot blue up did not work
How you wired it?
I expected it won't work but maybe will get one and give a try
