Hallo! Mr. Pecky! Can you help me, with pin code? From REC module, Astra H?
REC_ZIP.zip
REC_ZIP.zip
The code should be 8359. That dump is slightly different to the ones I have and the code is in a different place.
Could you check the code works and if possible post another dump just to confirm the read was good.
I can then add this type to my decoder.
but the dump with pin-code is in only one chip, atmel 25080, i am right?
Correct, it's just the VIN and code are stored in different locations to my dumps.
It is common that different modules have the code in different places. I just want to see if this is the case, or a bad bump
OK, I'll try this pin-code. if does not work, I'll try another programmer for this 25080 chip. Thank you very much, Guru Pecky!!!
The pin is correct! Thank you very much! Regards!
