Results 1 to 2 of 2
    Member broonfaedoune's Avatar
    Mar 2015
    Perthshire
    2
    Meriva 1.7 Diesel Automatic
    Meriva 1.7 Diesel Automatic engine noise problem
    As new to driving an automatic I assumed the whirring engine noise might be 'normal' but is now a cause for concern as it has been 'diagnosed' as possibly 1) from the turbo, 2) a bearing eg alternator, in the early stages of collapse.
    My own feeling having perused the net, is a possible fault in the diesel pump supplying the common rail (is the pump electronic or mechanical off the camshaft?). Whirring starts at various revs, low when started, at 1500, 2000 and over on acceleration - and appears to stop when the rail is 'charged'.
    Meriva bought s/h 6 months ago with 15100 miles on the clock, have only done just over 2000 on short runs, am pleased with it but want to make sure of reliability on long journeys. Any Ideas?? MHB.
      Mar 2015
      Perthshire
      2
      After the Vauxhall garages' full and fair assessment - road test, computer analysis etc. - Vikki (my Meriva) DOES have a permanent whirring/wheezy intermittent noise, diagnosed as 'passage of fuel through the system' and requiring no need of any component replacement! (Yet!?)
      I doubt this is unique to this one 1.7 diesel engine of its type - has anyone anywhere in the UK experienced the same? Hoping for some response Broonfaedoune.
  1. Replies: 3
    Last Post: 25th March 2019, 03:57 PM
  2. Replies: 1
    Last Post: 18th September 2013, 02:39 PM
  3. 2054 - Engine Z19DT/L/H/J and Z13DTJ/H - Diesel particulate filter clogged
    By pecky in forum Zafira B Technical Service Bulletins
    Last Post: 2nd July 2011, 11:14 AM
whirring noise meriva
astra 1.7 diesel whirring noise
whiring noise in 1.7 merivs
