code is 5966
Hello guys
Can someone help my to get security code from REC ith from ASTRA H 25040 EEPROM
Thank You
REC_ASTRA_H.bin
It works.
Thank you for code.
Can you help me with pin from BCM Corsa C EEPROM 93C66
I need to change ECU and i need PIN from that dump.
CORSA_C_BCM.bin
unable to read the format.. is that a hex file?
As soulman said, it looks corrupt
Gav
14 Zafira Tourer Techline FULLY LOADED
VAUXCOM UPA USB AUTODATA TOLERANCE AVAILABLE IN BRISTOL AND SOUTHWEST
not corrupted but looks like hex file
Did u come rightIt works.
Thank you for code.
CORSA_C_BCM.bin
Sent from my WAS-LX1 using Tapatalk
