Yes, it is.
Are u adding a uhp module to them both or are u using them in your own car?
I just want to use only radio in my car and pair it with my CID display, because now this radio is paired with GID.
No I don't have a UHP module in my car.
Ok then if using opcom deactivate your radio and display first with your original code then put other radio in then activate with code you have just asked for then deactivate
With same code then activate with your original code and should be ok
No worries let us know how get on just done mine cause navi bit stopped working and I had to get another cd70 without code once got code it was quite easy to pair up
Hi, uff, I finally pair it after few hours, thank you. Because I don't know that I must first disable present of UHP, reset and check fault codes and after that it can be divorced a paired.
This thing remember
Anything what you dont have
Dab, uhp or ecc must be set to not present otherwise it will fail because it tries to divorce all these things together
Hi!
Can anyone help me with the security code?
DVD90 NAVI
http://www.filedropper.com/dvd9024c64
Thank you!
