My answer is for member @dabi ... I don't know the answer for you question.sory I'm using PonyProg.
I'm sorry I do not speak well EnglishHi Damir,
As you can see in uper post's, I got the dump from my CD70's eeprom and sent it to a guy on the digital kaos forum and got back a devorced dump, had it writed in my CD70, using OPCOM I devorced the GID and CD30 from my car using my car's security codes then once more I devorced (deactivated theaf protection) the GID and CD70 using the codes from CD70 and maried up (activated the theaf protection) with GID and CD70 using the CD70's code. And its working...
Sent from my HTC One X using Tapatalk 2
The answer 'for me? Thx
I disassembled the radio know which side I start to attack her to get to the eprom?
Look at the photos.
http://postimg.org/image/x2le3pjez/
http://postimg.org/image/ff5dnnvdd/
remove navi drive eeprom is thereI disassembled the radio know which side I start to attack her to get to the eprom?
Look at the photos.
I had removed the Audio drive, ether way your target is accesable from the both side. I will try to find a picture how to conect the programer...
interesting under audio drive there is eeprom but it doesnt store any code so no point to look in that but under navi drive is right one
Yes you have an eeprom under audio drive witch stores the data of FM transmiter and something... And you also have conection pins access for needed eeprom(witch is phisicaly on the other side).
And this' 24C64..??
http://postimg.org/image/jkrq87uf9/
can be never checked as i dont prefer in circuit read and program sometimes can read/write wrong data safer to get solder station out of shelf and desolder
Exactly...And this' 24C64..??
