Hello,
I tried to solder the EPROM from the board. But the glue is very strong. I can not get it solved. Is there a tool that can read this and possibly other EPROM on the PCB? What can you recommend me?
Regards
Another read, saved as .bin
Thank you,
CD70 popa.zip
Hello,
Regards
Put a cutter blade under the chip, heat and push up.
I Try but i can Not Go under The Eprom with Blade good. There is Glue complite under the Eprom
Do you know how many times I've done this? Use cutter blade, it is thin enough. It will not go full, and its not intended to cut the glue, just to lift the eeprom, when tin is heated with hot air station.
as above, never had an issue with a blade and heat
I have a problem. Is it possible to pair cd70 display from other car which is not divorced. And another problem is that I cant plug in my old display because its already broken ( some parts are missing)
If your old Display still contains the eeprom desolder it and solder to new or read out eeprom of new and ask for pin.
Rgds
n0tiert
Astra H Caravan Z14XEP 18" OPC Line Rims
https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
