Yes it is KW ident.
Is it KW ident?
Yes it is KW ident.
Yes it will work in epc ident and part number are same for meriva and vivaro
Brilliant, thank you for your help.
I will try and sort a deal out with them on Monday.
Just got to sell the vectra cd70 and cid now. Could it be converted to work in a meriva, as it would help out fellow meriva owners ?
Cheers for your help.
There is chance but it involve striping your new one desoldering amd flash chip and eeprom with right tools quite easy job
Got the vivaro cd70 and cid today.
All tested and working perfectly. Just waiting for the housing from the main dealers.
Thank you for your help.
Got everything installed and working perfectly now.
What do I need to activate the board computer function ?
Can this be done by op-com or is it tech2 only ?
Thank you
I fitted it myself. It was just plug and play to be honest, very easy and working perfect.
