Page 13 of 13 FirstFirst ... 3 9 10 11 12 13
Results 121 to 124 of 124
Thread: retro fit ESP
  1. #121
    Member corsaedt's Avatar
    Nov 2013
    Turkey
    155
    Corsa Color edition 1.3 z13dtj
    yaw rate, abs ecu, brake main cylinder, servo, steering column(eps)..
    Sent from my iPhone using Tapatalk
    • #122
      Member fipusopu's Avatar
      Feb 2018
      n/a
      7
      Corsa D
      Quote Originally Posted by corsaedt View Post
      All of them for ESP? I though i would need yaw rate sensor and an ESP bump.
      Now I only have ABS, no hill assist, DDS, TPMS, ESP or anything like that.
    • #123
      Nov 2013
      Turkey
      155
      Quote Originally Posted by fipusopu View Post
      yes you need these
    • #124
      Member emes125's Avatar
      Oct 2017
      EE
      4
      Vectra B
      Can we sum up list of things tu buy ?
      EPS Column 112113111
      ABS/ESP pump AG5
      Yaw sensor 13267138
      Master cylinder brake ???
      Any more cabling than yaw sensor ?
      Is pump I mentioned fine just for ESP without DDS / HSA ?
      Can you also put some list of VIN, which has to be used for coding ?
  1. Heated seat retro fit
    By nathinspace in forum Astra
    Last Post: 2nd August 2018, 01:35 PM
esp retrofit corsa d
retro fit esp corsa
corsa d esp retrofit
https:www.diagnostics.org.ukshowthread.php3401-retro-fit-ESP
